flintandsteel
This appears to be a fairly common issue with variable fixes.
Mine (HC 260 in green) was dropping out regularly a few years back, Put up with it a while and eventually it fixed itself.
Recently it's started doing it again - anything from 20 seconds to 10 minutes.
Had a word with a friend who understands such issues.
Apparently as the solenoid pulls the contacts together they can arc and thus form a variable surface with tiny spots on them.
Solution smooth faces with very fine emery and it can run perfectly for years.
Mind you newer models may have different switch gear.
Thoughts?
Thoughts?
