I've read a few threads as well and had a first go at it a few weeks ago.
I used an old 12v car battery charger, rated as being able to supply up to 5 amps and its meter showed that it was supplying 2-3 amps when in use. This was with single small items (a plane lever cap, cap iron and blade) in a small plastic box with some old steel tube at each corner. I believe that the actual current drawn will depend on the surface areas of your rusty item and your sacrificial anodes, and the distance between them.
My charger is an old, simple one with just a thermal cutout to protect against too high a current drain. I've read complaints that if you go and buy a new charger it will have electronic controls which make it less suitable, but I've no experience of that.
I know that lots of people are very enthusiastic about electrolysis but I did not like it much.
It's very messy - the water soon filled up with a foaming brown sludge which made it impossible to see what was going on. The actual rust removal effect was no better than using citric acid which is what I have mostly done in the past.
