I have two pillar drills - one is in my modest 6 x 8ft garden workshop - the other in my brick double garage adjacent to my little metalworking lathe (a very old German Lorch watchmakers lathe). I'm just a hobbyist - my main interests are woodturning and the restoration of vintage valve radios, which, as well as electronics, involves a range of other tasks such as veneering, cabinet making and metalworking.
My workshop drill a 'FERM' brand nine-speed drill bought cheaply from a friend ten years ago, misguidedly thinking it would be more versatile replacement for the five-speed one I'd had for some years before that (later passed on to another chum). Surely 9 speeds are better than five - what's not to like? In theory yes, but in practice, whereas the five-speed drill had two pulleys and one belt, so changing the belt position on the pulleys could be done in a jiffy, the nine-speed drill has two belts and three pulleys, so changing the speed is such a faff that it's almost always set on 780 RPM, which I've found to be a reasonable compromise for drilling wood, MDF, aluminium, brass and steel. This is a classic case of 'more' being 'less' - in practice, my 'nine-speed' drill has become a 'fixed-speed' drill by default.
My second drill was an impulse buy from Aldi - a 'lockdown' Christmas present to myself in Dec 2020. It's similar, but not identical to the Einhell one presently on offer, and is branded Scheppach. I bought it to save me going back and forth from the garage to the workshop on occasions. It has a keyless chuck, laser 'cross hairs', a light, a digital speed and depth indicator, and the speed can be varied from 500 to 25,000 RPM. (The light, the speed indicator and cross hair display can be switch on or off as desired and has no effect on the drill).
What I hadn't appreciated before I bought it, was that the 'whining' of the integral motor would be so very noisy. Unsurprisingly, the whining noise increases in frequency and amplitude as the speed is increased, to a deafening level at maximum speed. Highly unlikely that I'd want to ever use it at top speed, (noise wise, think 'hammer drill on top speed with a 15mm masonry bit drilling into brick'), but even at low speeds I wouldn't use it without ear defenders.
As to the keyless chuck, whereas on a hand-held power drill this is an asset as both hands can be used to tighten the chuck, I've found the keyless chuck on the pillar drill fiddly to adjust because you really need three hands - two to tighten the chuck, and one to stop the drill bit dropping out of the chuck until it's tightened. Conversely, with a keyed pillar drill chuck, one hand can hold the bit - the other can tighten the chuck. I
It didn't come with a bench vice, but does have a useful clamp which slides up and down the pillar.
At the time, I think it cost about £120. However, at £160 for the present Einhell offering - twice the price of a small five-speed pillar drill - it wouldn't be on my shopping list. Incidentally, I've seen similar iterations of these electronically variable speed motors mounted horizontally in budget-priced woodturning lathes. Whereas a drill is used for a few minutes at a time, a woodturning lathe is often in use for hours on end. The noise level alone, apart from other shortcomings would make such a lathe a very poor choice and a chore to use.
The attached pics are:
1) The speed chart of my Ferm 9-speed drill.
2) The pulley speed adjustment diagram.
3) The three pulleys and two belts.
4) The Aldi Sheppach drill similar though not identical to the Einhell.
Hope that's of interest.
