Picalilli
Hi all - recently purchased an Axminster AW2305b bandsaw and I’m wanting to set up some dust extraction. I have a cheap triton wet and dry vac that I’ve hooked up but it’s not really pulling much out at all, so I’ve been looking at other extractor options. Is also like something quieter.
The bandsaw I have specifies 850m3/h airflow for extraction, but I’ve noticed that the lower model (1950b) specifies 390m3/h.
The difference in the two is that the smaller one has an outlet of 63mm while the one I have is 100mm.
https://www.axminstertools.com/axminster-workshop-aw2305b-bandsaw-230v-107999
https://www.axminstertools.com/axminster-workshop-aw1950b-bandsaw-230v-107711
What I’m wondering, is why is all of that extra airflow required for the slightly larger saw - aside from the outlet being bigger? I suppose what I’m thinking, is why couldn’t I just step the outlet down to 63mm and use a dust extractor with less power…? Surely the difference in the actual sawdust created doesn’t change? Just seems odd that the larger one required double the airflow when it’s essentially doing the same work, just with larger wheels?
Am I missing something?
Any advice on the best set up to go for is greatly appreciated - my main restrictions are budget (ideally <£300), size (compact as possible). I like the idea of a wall mounted one, something like this Axminster one, which actually comes in at exactly the airflow I need, but wondering whether it’s wiser to go slightly higher? This is the only machine I’ll be hooking it up to.
https://www.axminstertools.com/axminster-workshop-aw37e-dust-extractor-230v-107695
