yetanothersmith
Hi everybody. This might be a bit of a random one but I want to drill a 3-3.5mm hole through a standard PH2 1/4 inch hex screw bit for a multitool project I’ve been playing around with (corona lockdown makes work for idle hands!) You may not be surprised to learn that they’re really hard! Most centre punches bounce off them. HSS drill bits won’t touch them either. I’ve had partial success with cobalt bits but have yet to make it all the way through before the bit stops cutting. I’m keeping my spindle speed low, not applying loads of pressure and hopefully not generating too much heat (although I’m not using cutting fluid). Any bright ideas of where I go from here?
Thanks in advance,
Pete.
Thanks in advance,
Pete.
