I have used a 750W Makita drill in the Record Power stand and it worked just fine - but not on 50mm Forstners!
To an extent, it depends on the wood being drilled and how sharp the Forstner bit is, but I found the drill to be lacking torque at the lower speeds suitable for the Forstner, even with the gearbox switched to the lower speed.
It is possible to drill holes in this way, but certainly not ideal. Don't forget also, that the stands pictured need to be screwed to the workpiece or anchored in some other way. Fiddly and frustrating.
Duncan
Duncan
