Meaning to do this for a couple of years...
Metal plate on the drill press....
Random piece of MDF. Needs using up. 18mm
Marking an arbitary line to determine the width...
Marking up the MDF before cutting on the tablesaw
To add some rigidity adding a skirt on the front. (ash)
Centre punching for some screws...
Screwfix twin start screws..
Cutting some side cheeks to hold it to the table snugly...
Snapped a screw - luckily managed to get the molegrips on it to extract it...
Dunno, random clamp shot...
Never thought how I'd use the handle for lowering and raising the table...
Better sort that out...
Thats better...
I've drawn some lines in marker pen at 5cm intevals. Just as a rough guide.
Routing a 6mm slot..
Got a sliding fence...
Adding some hold-downs...
Little hole for the countersink - thats never had a home before!
First try out!
Bit of danish oil...
Hole to secure it to the table..
Bit of polish to make the fence glide...
Adam
Thats better...
First try out!
Adam
