sploo
Somewhat extinguished member
In a thread in the metalworking forum I detailed some repairs and upgrades to a Mini Mill. I've been making do with a little flexible arm LED light, but it's not ideal, so decided to install something better. The solution is just as useful for a drill press; hence I'm posting this in the general projects forum...
I bought some 12V car ring lights from Amazon "Qasim 1 pair of LED COB Angel Eyes Halo Rings with Plastic Cover 80MM 3.15'' White 63SMD for Car Motor DRL Headlight Fog Light DC 12V" (Qasim 1 pair of LED COB Angel Eyes Halo Rings with Plastic Cover 80MM 3.15'' White 63SMD for Car Motor DRL Headlight Fog Light DC 12V : Amazon.co.uk: Automotive). These are the 80mm version, as the 68mm internal diameter is right for my application.
To that I added a 12V 1A power supply with a 5.5x2.1mm jack plug. The light takes less than 200mA, so it's plenty.
I also bought an inline switch to allow easy control of the power (LitaElek 2pcs DC 12V Inline Switch Cable On/Off Rocker Switch DC Jack 5.5mmx2.1mm Male to Female Connector to Connect Flexible LED Strip Flex LED Tape Ribbon Light CCTV Camera to Power Supply Adapter : Amazon.co.uk: Lighting)
The male plug was removed from the switch, and a few minute's work with a soldering iron and heat shrink tubing gets me this:
The light has a sticky backing, so was easy to put on the underside of the mill. The switch was also attached with some double sided tape:
With and without, using the same camera settings:
I also added a second to my drill press. The long quill travel means the light is shadowed a bit at the point of drilling if the quill is lowered, but it's definitely better than nothing:
