Cozzer
"With this adapter, you can attach your Dremel (M19x2) to your milling machine with 20mm diameter tensioning clips."
Any seller in the UK?!
...although reducing its OD to 20mm would leave it awful thin....
...point
ChaiLatte did make a good point, Phill05, and got me thinking whether it's a bridge too far. I'll explain...Can you show me what you want I am unsure what it looks like, I have made some parts for the Dremel but I would need to see what it is.
only to find that the yellow clamp is really designed to hold 20mm collars. Yes, it will open wide enough to tighten around the threaded grey bit, but that's plastic...and would need to be tight....and who knows what damage it could cause to the thread?
You could batter both birds with the same rock by wrapping the grooves of the male threads with string to pad them out to the tips and then finish with a couple of wraps of insulation tape. That will make the diameter up to 20mm and spread the load so damage risk is eliminated.
Shame it's not available in UK, looks really nice. Hey @benchdogs how about it?This Dremel base is a thing of beauty and very reasonably priced:
https://www.stewmac.com/luthier-too...uters-and-bits/routers/precision-router-base/
It's on sale at a discount $59,99 at the moment, still 6 in stockShame it's not available in UK, looks really nice. Hey @benchdogs how about it?
