I'm making a file cabinet and I installed the first drawer using Accuride 4043 drawer slides. These are a type with the rails that ride on top of other rails so the whole slide is about 3 inches wide. After installation, I found that it seems to work fine, but the drawer will shift from side to side by about 3/16". I'm concerned that this will be a problem because I'm doing inset drawers and have cut the drawer fronts 5/64" narrower than the opening. The user will be able to shift the drawer over far enough that the drawer front hits the frame. (The drawer front is not yet attached to the drawer.)
Is this amount of side to side play normal? The "light duty" sides I have around the house don't seem to do this.
