carlb40
This is something i started last year. Picked up a 10'' Dovetail/ Tenon saw from ebay for less than a fiver
No name just the usual warranted superior on the medallion. Plus the usual cheap beech handle.
After removing the rivets/ medallion i dropped the blade/ spine in some oxalic acid for a bit to remove the rust. Then took various grits of sand paper to the blade/ spine.
After buying a piece of curly maple on ebay, i used a piece of it for the replacement handle. I had to laminate 2 pieces to get the thickness. After printing off and sticking the template to the blank, i did a bit of drilling/ sawing.
As you might be able to see on the last pic i had to do a repair. I had used my TS to do some cuts, but went a bit far and cut into the handle section. #-o
So i carefully made and glued in a small splice.
Then it just sat as i got busy at work so things fell behind.
Then enter today. As my toolbox WIP is slowing down due to glue ups etc. This was restarted.
1 - To get it finished
2 - I need the saw for the tray build part of the toolbox WIP.
I marked up and cut the slot for the blade. Used one of my jap saws to cut the curf, fitted quite nicely after a couple of passes with the saw.
Then onto the spine. Marked out and carefully chiselled out the waste with a 3mm chisel.
As you can see it still needs a bit of fettling to get a better fit. Don't worry Klaus/ Pedder and Mr Nielsen have nothing to worry about. :lol:
