A little while ago Workshop Heaven started a saw handle making competition. I saw the post and thought, that could be fun. I then largely forgot about it for a few weeks. Then about a week or so before the end of the comp, I thought, I ought to actually do that. So in a bit of a hurry I bought some wood (striped african ebony), a couple of rasps and got cracking.
First I glued the paper outline to the blank and drilled out a few holes.
I then got the fretsaw, cut out the worst of the waste and did a bit of initial shaping:
Then a lot more shaping, polishing, then cutting and chiseling to accept the blade. I did the cutting of the handle with my japanese saw. However the ebony finally did for the saw and it's pretty blunt now. There is a method for cutting the handle where you use the blade of the saw to cut the handle. I did try this on my initial handle (made out of sapele) but it didn't work well. So I just clamped it up and cut it very carefully.
I've attached a few more photos, which I took for the comp.
