SLM
Oh, don’t go there!But you need sharp chiesels!
Or you can't do it maybe just a bit more practice?I suspect that by the time you've farted about setting up the jig, you could've done half the job without it. Dovetails aren't produced by a sort of secret magic, using knowledge and skill only available to initiates after a long apprenticeship. There's only one trick involved - which is cutting accurately to a line. And if you can't do that, you might as well forget about woodwork altogether ... because it crops up all the time.
Usually sand them flush myself, but those dovetails look great! Am going to try that as well, really classy.A trouble with jigs is that you often seem to need a degree in mathematics - which isn't my aptitude! I've never had a jig, but I've made quite a lot of dovetails that I had to get out of the door to a quoted price ... all different ...
(Corner of chest in native oak)
He he, cool idea! No one notices them anyway.Buy a used Woodrat, once learnt they deliver fine dovetails that look hand cut apparently. Now for some sacrilage, I would like stick on dovetails so once you have used a lock mitre joint or something similar then you can just stick them on so it looks like dovetails, maybe a stick on veneer!
Oh.....sacrilege for sure. One trick I've used is to rip off a 4 mm thick board at the front of a drawer, make all the dovetails front and back as through dovetails and then glue on the 4 mm piece . You have instant half blind dovetails. Having used the same board the joint is virtually invisible.Buy a used Woodrat, once learnt they deliver fine dovetails that look hand cut apparently. Now for some sacrilage, I would like stick on dovetails so once you have used a lock mitre joint or something similar then you can just stick them on so it looks like dovetails, maybe a stick on veneer!
Hey that's my table!At least when you use a jig, you dont end up with crazy angle joints like these. What are they ? 45 degrees
PS have tried 45º, works OK, looks interesting and original, but might cause heart attacks in older woodworkers - they tend to be very timid and dependent on gadgets: pacemakers, honing/dovetail jigs, hearing aids, incontinence underwear, etc
