Chris Knight
Alf":310uih6v said:So maybe it is indeed a male thing and you like it for all the wrong reasons?
Entirely likely!
:shock: Rather you than me... :-s My gut instinct is you don't want a fancy joint in a fancy wood, but I'm probably quite, quite wrong. Be interesting to see how this one turns out, Philly.Philly":1v0w1yv3 said:Material will be 50 mm thick, hopefully Zebrano.
Philly":3gw9w2up said:hopefully Zebrano. You can see how the double dovetail might look good on this. or not.......
Any other ideas for joining the top to the legs? Biscuited mitre, secret dovetails, dowels?
Alf":1wb9xjmb said:My gut instinct is you don't want a fancy joint in a fancy wood...
Philly":e754rn7c said:...I was thinking about veneering but have never tried it (and prefer working in solid wood!).
Philly":e754rn7c said:...It has to have that slab look to go with the fireplace. Any other ideas for joining it in the solid but retaining that mitred look? Loose tenons?
Philly":e754rn7c said:...You go ahead and make one! I'll be starting mine in a few weeks time
waterhead37":1th5gorw said:... Personally, I would veneer ply rather than solid wood but that is just my parsinomious nature! :lol: ...
Philly, we haven't seen any gloats from you for what feels like months (must be over a week, then :wink - isn't this a great opportunity for some gloatsome new kit like a vacuum veneering press?waterhead37":2il3vo7r said:Personally, I would use this as an opportunity to do some veneering
Alf":2lrgjl4e said:Good point, Neil. Whatever happened to a project not being worth doing unless it needs a new tool to do it? Tsk, what kind of example is this from the Gloatmeister? [-X
Cheers, Alf :wink:
mudman":1roqssfb said:So what do you think the Dyson in the fireplace piccy was? :wink:
