ByronBlack":1fnvus12 said:
Thanks for that dave - thats what I had in my mind but I got a little confused from Jacobs mentioning of the full-scale drawings, like I would do anything as professional as that!!
Your most welcome to come over and inspect my work, you may be able to help me lift the heavy bench into place
OK its drawing but its not Leonardo de Vinci so don't be put off - nobody's going to see it except you. Just see it as a record of the measurements you've taken or worked out.
I'd advise keeping your bench design simple - ignore those rather affected designs with slightly splayed legs etc - difficult to do and pointless.
Assuming a simple design, what you do is:
get a piece of board, ideally a 6" wide length of MFC from B&Q, longer than your bench.
Pencil in 2 lines with your square, at the length of your top boards. TA-DA thats the 1st bit of rod - you now can lay on the boards you've prepared and take off the lengths with a set square and a pencil, knowing that they will all be exactly the same, but you don't do it yet - you start the cutting list when you have completely finished the rod.
Then pencil in 2 lines for the width of each of the legs in position relative to the top marks you made earlier. TA-DA you now have the 2nd part of the rod - marks which show the length of each rail and apron and the position of the shoulders. You now pencil in lines for the haunches and TA-DA you now have ALL the horizontal marks you need for the rails and aprons.
Then do the same for the width of the bench etc. You could overlay the width drawing on top of the length drawing if the legs are square, to save a bit of drawing , or you could do it separately to save confusion.
You then do something similar for the vertical bits: on the opposite edge of the board put in marks for the ground to bench top height, then the thickness of the top boards (TA-DA that gives you the length of the legs), then the position of the rails and aprons etc ( gives you position of the mortices), then details of mortice haunches or however you are doing it. And so on.
You could mark in the the depth of things on the board with a combi square and a pencil, at which point it starts looking like a full sized drawing. You could add details about vices and so on, as much or as little as you need.
To take off the marks you lay on the planed square pieces (marked with face and edge) stacked up - face mark to face mark where they are same but opposite, and mark with a set square and pencil.
Does that make sense?
Re drawing - it's inescapable for a woodworker you can't manage without it. Just a simple drawing board, T square, set square, pencil and rubber, scale or two. Don't bother with Sketch-up or other drawing program they are a waste of time and useless for our purposes.
cheers
Jacob
