When I look at the Cathedral in Durham, over 800 years old and still lots of original woodwork, I know upvc will not last that long. Real wood has a look and feel that cannot be replicated, both UPVC and MDF prove that so nature knows best.
I agree that - properly designed, made and maintained - conventional timber windows are great, and much better than plastic for all sorts of reasons. The only sticking point is that - in my understanding - building regs force the use of double (not single) glazing to get a suitable U-value of thermal performance. Using DG units in timber frames is what I'm assuming the OP wants to do (and/or will have to do to conform to Part L of the build Regs) and the points I was making are in that context.But "10+ years" is a very short time. Trad joinery can last 100 years or more.
Cost of replacing DG units at 10 or even 20 year intervals is likely to exceed any heat savings many times over.
Not that cold in UK, unless the Gulf Stream stops!My house has triple glazed, coated and gas filled PVC windows......
Why would it be legislated out? It's highly durable and relatively low carbon as less energy goes into making it - no alkyd synthesising processes, doesn't need fossil oil derived thinners etcis difficult at best and linseed oil paint is special order from specialty companies and is two or three times as much to buy. Have no idea how long the paint will be available before being legislated out. ....
I think it's because our houses are already too small, and having inward opening casements would further reduce the space.Around here the traditional type of double glazing is casement windows with the outer casement opening outwards and the inner casement opening inwards. Both casements are single glazed and together they form a double glazed unit when they sit in their own rebates in the jambs. Made from good quality pine theese windows normally last somewhere between 50 and 250 years if properly maintained all depending on how exposed the facade is to the weather. Made from oak they seem to last indefinitely.
I don't know thy Brits seem to believe that double glazing per definition must be made with those short lived sealed units.
I think it's because DG is a relative novelty still - it only got going in the 60s when plastic windows started replacing wood and never evolved far. No tradition in other words and anyway our climate is nowhere near as cold as Finland or Canada.Around here the traditional type of double glazing is casement windows with the outer casement opening outwards and the inner casement opening inwards. Both casements are single glazed and together they form a double glazed unit when they sit in their own rebates in the jambs. Made from good quality pine theese windows normally last somewhere between 50 and 250 years if properly maintained all depending on how exposed the facade is to the weather. Made from oak they seem to last indefinitely.
Inward opening common in France - made possible by having tall narrow sashes which fold back into the window reveal and hence take up no space. They have outward openers too but as solid or slatted shutters un-glazed.I think it's because our houses are already too small, and having inward opening casements would further reduce the space.
I was chatting to the fitter (an excellent self employed fitter - I have fitted windows before) who did my two front windows this summer. I commented that the payback time between A and A+ rated windows was several decades (way longer than the windows would last) on the prices I'd been quoted and he agreed, saying also that a problem with many he'd come across was that the sealed units weren't actually the rated to the level the vendors had quoted for anyway. I asked what he thought about triple glazing and he said a total, utter waste of time in this Country - the units are made to fit standard double glazing frames (4mm - 20mm -4mm) so any any possible advantage of three layers of glass is lost by the gaps being too small.My house has triple glazed, coated and gas filled PVC windows ...
I wonder where I live if it would make sense to have inward opening windows and outward opening doors.Inward opening common in France - made possible by having tall narrow sashes which fold back into the window reveal and hence take up no space. They have outward openers too but as solid shutters not glazed.
But not in terms of saving. Rule of thumb is that 20% of heat is lost through SG windows, halved if DG. 10% of your bill. For me about £100 p.a. DG would be a complete waste of moneyDouble glazing is a no brainier in terms of thermal efficiency.
Not if there is a normal (essential) level of ventilation and insulation. I've insulated all the walls with 100mm Kingspan between studs so the inside air RH is nearly always above ambient levels. I get a bit on very cold days but have a condensation drip catcher in the cills, draining to the outside. DG plastic get condensation too and often have similar detailsingle glazing in a modern, draught proof house will suffer condensation
True-ish, but not much of an issue and curtains fix it at night. We have close fitting roller blinds on some of themThe air next to a single glazed window will feel cold - as the glass face will be similar temp as outside - it will even create droughts making the effect feel greater.
I'm just curious why you say the timber is not of good enough quality over here? Pete
Thanks Kieran
Not that cold in UK, unless the Gulf Stream stops! Why would it be legislated out? It's highly durable and relatively low carbon as less energy goes into making it - no alkyd synthesising processes, doesn't need fossil oil derived thinners etc
I can comment on longevity sound and comfort. My windows were changed 45 years ago they are mostly aluminium thermal break units with 2 wood units.I have read that secondary glazing is better for sound insulation and the bigger the gap the better but the thermal insulation isn't as effective as argon filled etc.
This leaves me wondering if I still go ahead as I dont want the hassle of replacing failed units.
I seem to remember Historic Scotland looking at properly maintained timber versus PVC and I think the timber came out better. I don't think they looked at single over double-glazed.Double glazing vs Single glazing.
- Participants
- KieranJW
- ian33a
- Start date11 minutes ago
EditStarMark unreadLeave
K
KieranJW
New member
11 minutes ago
Hi,
Just read your message about the glazing by a door. I was interested in the 16mm reference to the gap between panes.
I have had a couple of customers now having windows made with Single glazing. I have done a reasonable amount t of heritage repairs and have always preferred the single glazing.
In the next year or so I will be exnteding my house and when I do I would like to replace all of my existing Pvcu windows with wooden windows using linseed paint and am deliberating on single glazed vs double glazed as my main reason for doing wooden windows is that if I do them once I should not have to replace them in my lifetime whereas I notice most people are changing pvc after around 20 years due to them looking tired.
I have fitted secondary glazing for two customers in past employment but the company did it with perspex. Apparently it was effective but never found out the longer term result.
I also though that if a dessicant can somehow be fitted in the gap it should reduce the moisture issue.
I have heard of a chinese double glazing unit that can be refilled (and I assume resealed) but never found out the name.
Any advice or discussion would be appreciated.
