SammyQ
Everything works? Job done that man!
One word of caution? If you have a saw blade on the RAS sliding back and forth on cuts, it's easy to forget it's there....when you then twist the head/arm through 90 degrees to enable table saw or planer, guess what is still spinning? This also holds for using the mortising table.... Take care!!
Sam - who had a close shave one day.....
