Late 1970's house. Gas fired CH and HW, originally copper and I do all my own plumbing maintenance (except the boiler).
Over the years I'm sure I've noticed a drop in the quality of copper pipe. I know it's made to British Standards but like for like, when I've weighed lengths of pipe I've taken out of the system vs new stuff, the new is 10 to 15% lighter. I've also learnt to carefully inspect any lengths I buy carefully before leaving the merchants as so much pipe is bent, ovalled, damaged ends, excessively deep stamping aand worst, longitudinal scratches which are a pain when you are jointing copper to plastic relying on push fits with O rings.
On a retrofit as opposed to new build, changing from copper to plastic has several disadvantages so I need to keep a lot of the system in copper.
Is there any source of "good" 22mm copper pipe folk can recommend ? Better than the standard Wednesbury, etc stuff from SF and TS which suffers all the problems I've listed above.
