Doll wardrobe for the step daughter (Complete)
markblue777
2 Dec 2013
Waltham Cross
Hi All,
Another project in the works
My step daughter asked me if I could build her Barbies a wardrobe so I said yeah why not. I was going to make it out of some mdf I have lying around but on saturday we was doing some spring cleaning and I found an old wine rack that had never been used (think the misses got it from a charity shop). So instead of binning it I thought I would reuse it to build the wardrobe.
I don't have any picture of what the wine rack looked like before but here are a few shots of the wardrobe
The basic shape all done
Then with the added shelf for Barbies shoes
There is not going to be any doors and I have since put the pole in for the cloths (will get a picture tonight)
The colour is to be a hot glossy pink (honestly not my choice :wink: ) with the Barbie logo put on the top of it and a mirror attached to the side.
I am thinking of maybe putting a little LED at the top to light it up but not 100% yet.
I will be priming it tonight as long as the weather stays dry.
Mark
Here is a picture with a test fit of the cloths
Pre filler to cover the nail holes
filler all applied (would like to do more but the client is pressing as her dolls "need a wardrobe")
I have sprayed the under coat on but need another going over after a sanding then can do the neon pink colouring that has been selected.
Mark
So here is another update
Here it is all primed up
but then there was a need for a door. As I never had the material around I was wondering what to use then I remembered I had some 3mm perspex so I cut a couple of channels so the door will slide in and keep everything in place.
The channels before they were also painted
This is how the pink looks on the shelf, it is definitely a sun glasses job when looking at it.
a design decision has been made that the interior will be kept white and just the outside pink (with the exception of the shelf which will stay pink.
More pics soon
Some more pics of the project
All masked up
and all painted
mask up was not as good as i thought as some spray got through in a couple of random places. So i am having to touch this up by brush
with the shelf and the cloths pole in and some cloths hanging
With the late addition of the slide in door so keep everything in the box
I still have to find a Barbie stencil and spray it on the top and then lacqure over it to give it some protection. Then I have to make a small mirror to put on the side of the wardrobe.
Hopefully should be able to get it finished off tomorrow possibly.
Mark
That's one cool funky looking wardrobe- nice work btw ;)
Won't be long till you go into batch production once her friends see it !
Sent from my GT-I9300 using Tapatalk
Well I finally got around to finishing the wardrobe off the pics are below.
The only thing done here was painting on the Barbie logo and then a couple of coats of clear lacquer for protection.
Mark
Looks good now it's completely finished ! So did you end up spraying the barbie stencil or hand painting ? Looks very neat ;)
In the end I found the logo and printed it to the size needed. I then cut the main lettering out and used that as a stencil to draw around then neatened the stencil up so it looked more like the actual logo and I then painted it the white (i think it was 4 coats with rub downs in between) I then used a sharpie for the border to make it pop a little more
Mark
