I've turned a lot of knobs in the past. No need for extra kit.
In the end I found it easiest and fastest to turn them out of one long cylinder blank , marking up each knob, picking out the details on each - which helps make them identical, then finishing the tailstock one as near as possible, reducing the spigot and parting off, tiny bit of hand trimming/sanding to remove the tail stock mark, then on to the next one with the remains of stump of the spigot on to the tail stock.
Found it quite fast eventually, very repetitive which makes for accurate reproduction of identical (near enough) copies.
PS tried a Jacobs chuck but it tended to crush the spigot.
NB spigot only needs to be fractionally smaller then the knob e.g. a 1" dia knob could have a 3/4" spigot - no point in making them smaller.
PPS i've just remembered - for finishing the last little bit I sometimes mounted the knob in a piece attached to a faceplate with a tight hole to fit the turned spigot.
