Phil Pascoe
^^^^^^^ see above. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Tris":3roe2ecm said:All you need in the kitchen is a side axe- flat bit to crush garlic, curved bit to chop everything else. Anything it won't go through just needs boiling another day or so :lol:
Cheshirechappie":3m48gwsj said:Tris":3m48gwsj said:All you need in the kitchen is a side axe- flat bit to crush garlic, curved bit to chop everything else. Anything it won't go through just needs boiling another day or so :lol:
Now you've been and gone and done it!
Next thing we know, there'll be some wazzock advertising ceramic-bladed side-axes with exotic hardwood handles. Only £1,000 a pop! :lol:
:lol: :lol: :lol:Bm101":34ap4uuw said:*carefully writes down in ideas notebook*
cer..a.. mic-bladed siiiideaxes with exotic Haaaaard woooood handles. Full stop.
On...ly £1,000 a pop!
Jimson":30gcbx1m said:I do, and it's my first post. Perhaps I don't get the joke yet ...
Anyway, if anyone can help - I want to re-grind the primary angles on some bevel edged chisels and a couple of plane irons to 25 degrees. I haven't been able to do it myself even with the coarsest papers and have made a bit of a mess of them. There's a local service which will do them using a surface grinder. Is this likely to overheat and damage the steel in the chisels and plane irons? The man at the shop said he would do it without taking much off and so thought he could do them without damage, but I'm not so sure. Any advice much appreciated. Many thanks.
Pete Maddex":3lc82g2z said:Jimson":3lc82g2z said:I do, and it's my first post. Perhaps I don't get the joke yet ...
Get the coarsest paper you can find stretch it tight I use clamps to clamp it down and others to pull the clamps apart.
Stick the blade in a honing guide and have at it, check the temprature of the blade as you can build up some heat
This is my set up used for cleaning shoulder plane sides but it works for blades.
DSC_0054 by pete maddex, on Flickr
A long-standing issue we've had has finally been taken care of (not before time in the opinion of many). Had it not been this thread would not have been viable because it would almost certainly have been derailed by argument and infighting, and this could have started as early as the first page! This sort of thing marred >95% of sharpening threads (and threads on other topics, as some of the jokes early on refer to) going back years and years.Jimson":1vh2bcc7 said:I do, and it's my first post. Perhaps I don't get the joke yet ...
Have you been attempting to do this freehand? This is doable, but it certainly helps to have a good grasp of freehanding before you start; on the other hand it could become a valuable training exercise to get good at it!Jimson":1vh2bcc7 said:I want to re-grind the primary angles on some bevel edged chisels and a couple of plane irons to 25 degrees. I haven't been able to do it myself even with the coarsest papers and have made a bit of a mess of them.
Surface grinders should be capable of this but the way the machine is run is the deciding factor, i.e. it's down to the operator, not about the process in the abstract. I've read both good and bad stories of what people have had done by pros running surface grinders.Jimson":1vh2bcc7 said:There's a local service which will do them using a surface grinder. Is this likely to overheat and damage the steel in the chisels and plane irons? The man at the shop said he would do it without taking much off and so thought he could do them without damage, but I'm not so sure.
