slemishwoodcrafts
First off, I know this topic has been done to death on this forum and just about every other woodworking forum I read on a daily basis.
But I am going to share this work in progress anyway as I haven't seen a cyclone built this way before. (Not saying I'm the first to do it, just haven't seen it documented before)
I built a cyclone last year using an old burgess boiler and a traffic cone and whilst it was somewhat effective I found that the diameter was too small to effectively work with my 6" ducting.
Doing a bit more research again and I realised I needed a minimum 18" although around 22" would be ideal. I measured up an oil drum and found it to be 23" in diameter. Near enough perfect. So last night I measured up and made the first cuts with the grinder to transform the lower portion of the oil drum into a conical shape. I will post further updates as I progress and I hope to be finished by this weekend
