Argus
If it is a very valuable stone you could epoxy it into a box to hold the pieces together (without actually putting glue between the cracks)
Agreed...... a wooden box/frame will hold it together, but you will sacrifice the use of one side, however you should then need to re-flatten the surface of the user-side.
It'll be a good idea to sit it in a warm place for a few days first to remove as much residual moisture as you can to avoid compromising the epoxy bond.
