i think it's a good thing.
I can't see the argument against it really. Unless you are a gas or oil producer.
I did read an article a week or two back about converting to hydrogen gas. We can use excess electricity to generate hydrogen, store it, use it to replace methane. Imagine, hydrogen to your home. Now how about replacing your petrol (or electric as I have) with a hydrogen cell. Starts to make sense to me.
The main problem with ground source systems is that, at present, any radiators need to be somewhat bigger than at present because the heat of the water in the pipes is lower. This is added to the fact that the space for the equipment externally is greater.
Phil
That's why a developer I know owns (with his family) a couple of dozen different companies.IIAC, if a developer builds less than four hundred houses, they are not under any obligation to provide any addition to the local infrastructure.
Nigel.
In fact, the energy extracted by a GSHP is principally solar - the sun warms the earth. And large areas are not required. We heat 270m^2 of house off about 300m^2 of garden by using bore holes. Designed properly, the effect on the ground temperature is negligible, as the thermal conductivity of the ground is taken into account when laying out the bore hole locations.Ground source heat pump systems
In theory, seemingly great idea, especially if you have the land space.
There is one glaringly obvious problem with them when used enmasse, like entire housing estates.
If you continually extract the ground heat on a large scale, then obviously the ground temp will decrease over time in that area, affecting the local habitat greatly, even to the local extinction of insects first, then the obvious knock on effects.
On earth you don't get something for nothing, see first law of Thermodynamics.
The only energy we can ever use that will have no impact on this planet is that which eminates off planet, ie solar.
Even then the impact on resources to make solar systemd and batteries is still a drain on finite resources.
The property developers are only interested in selling a very cheap box for maximum profit and have no interest in the buyer, but why do councils allow them to build on known flood plains! It is true property companies have more clout than the local council, brown envelopes speak and they just destroy whole communities by excessive developement on green fields rather than brownfield sites.What is unforgiveable is that councils still approve construction which fails to meet (or even get close to) what can be achieved. Assuming they understand the issue, they are often under pressure from developers keen to minimise costs and maximise revenue.
I read a comment in the Press the other day from someone who said the government is going to have to do something about electricity pricing if they expect everyone to accept electricity instead of mains gas when the standard B. G. tariff for electricity is 19p per kwh and for gas 3.5p per kwh.
Negligible in isolation, but massive when upscaled to 100s of properties in close proximity.In fact, the energy extracted by a GSHP is principally solar - the sun warms the earth. And large areas are not required. We heat 270m^2 of house off about 300m^2 of garden by using bore holes. Designed properly, the effect on the ground temperature is negligible, as the thermal conductivity of the ground is taken into account when laying out the bore hole locations.
I’m not sure what IIAC means Nigel but that is not correct. All local councils have the right to apply a Community Infastructure Levy And do. I think it came in from 2010 for developments that add more than 100 square metres of dwelling space. There are exemptions such as when affordable or social housing is included in the development.A colleague of my wife lived in New Zealand for a number of years. The property they lived in had heating provided via a ground heat pump. In her opinion, it just about took the chill off the house.
Nigel.
They may be more efficient but they are not efficient enough, there are huge improvements that can be made but need to become a legal requirement under building regulations.
A large local firm tried to introduce that about forty years ago, the idea being that as most of their people were regularly doing overtime it would allow either a three day weekend or for the overtime to be done on the Friday thus still leaving the weekend. Most of the men (mining machinery, it was virtually all men) though it was a great idea, but the unions involved wouldn't have it.(personally I would love to work 4 days a week x ten hours, imagine a three day weekend every week).
