Gidon, this was the quote I had from Kemet - I think the cast iron plates are circular - probably fine for hand lapping, just have to learn a slightly different stroke - for running a jig on, not so great but of course one can always mount them in a larger area of something to run the roller on (as I already do with my DMT so I can use the full length)
I think GP4 is suitable for all grits, no info to the contrary yet, we could check. Jeff Brown was the guy I spoke to at Kemet. It's a shame they don't sell other shapes/sizes of plates - maybe they would be willing to just supply some rough cast iron of the right grade, we can machine/lap it ourselves if we want to
342743 6" Cast Iron Plate £51.00
342705 8" Cast Iron Plate £61.60
E04069 Kemet GP4 Sheet 6" x 2" x 18mm Thick £14.38 Each
Please note item 3 has a minimum order quantity of 10
A 'full sharpen' for me (new primary bevel) means I go from 80grit on a belt sander (not a worn belt) to a 15 micron (red) DMT (quite worn now) to blue compound on leather - gets a fine polish in only a few minutes start to finish. I sometimes use an oilstone instead of DMT but DMT is usually faster, and seems not to cause any problems. Now I'm honing at the end I am finally getting 'shaving sharp' edges much better than without. The very slight rounding towards the edge from honing is probably a good thing for edge life (the back is still as flat as I can keep it, I can hone on a hard surface like MDF).
Using loose diamond rather than DMT will just mean never having a worn-out middle stage abrasive in this sequence...
happy sharpening
Miles
