Silly_Billy
I'm hoping for advice about how I can learn to diagnose sharpening problems and ways to improve. I've done a sharpening course and haven't had any problems sharpening until today.
Today I was sharpening my No.4 smoother. It's a Quangsheng plane with a T10 iron, and I love using it. Until today, I have always been able to get it razor sharp (i.e. sharp enough to easily shave hairs). What could I have done wrong today?
I was wondering if diamond stones can wear away because I've used them a reasonable amount. However, I am expecting my technique to be the more likely cause of my woes.
Any help or advice would be much appreciated!
- The blade has been ground to 25 degrees using a 120 diamond stone. (I have little space and no power for a grinder.)
- I added a bevel at 32 degrees using 1000 diamond stone. It seemed to take considerably longer than usual to reach the point where a burr formed.
- I removed the burr on a 8000 diamond stone and then added a bevel at 35 degrees. Again, it seemed to take longer than normal for a burr to form. Also, the edge didn't look uniformly polished. I wondered at first if some of the diamonds had worn away on one side, so I flipped around the diamond stone. But I was still left with inconsistency in the polished edge - one side didn't seem to reach the same degree or mirror finish.
- Finally, I used the ruler trick to add a back bevel with the 8000 diamond stone. When I inspected the edge, it looked like it wasn't straight :shock:
- For all angle measurements, I used a honing guide.
