matmac
Hi guys I’ve just bought a europac model. Looks great but having trouble aligning stuff. Blade keeps burning. Just had blade sharpened so not that. Any tips would be a good send. Cheers
I have had a few touchy moments with mine but the inverter that powers it has cut power and instantly stopped the blade. Its been when the blade catches and deflects because I pulled it through the material to fast. Its a great addition to any workshop!
I have the DeWalt 1501. It has a self resetting thermal shut down if it's overloaded, but wouldn't trip the circuit.
If the blade had come loose, the motor may have stalled perhaps overheating the motor, but you think the overload shutdown would have kicked in to protect it?. Perhaps it did, but without the fan running it overheated the coils before reaching the overload shutdown? perhaps others have better advice. Unfortunately it sounds a bit terminal. £440 for a replacement
I have a suspicion that the overload takes a few seconds to operate. When I'm using the saw, I can predict when it will shut down by the sound of the motor. I think it's a thermal shutdown, because it takes a good while to reset. My saw doesn't have a reset button. I think a motor repair may be a cheaper option if you want to keep the saw. There are a few motor experts on here who will be able to advise better than me. Used saws seem to go for about £350ish, just what you paid for it new!Thanks for your reply I thought the overload would have kicked in it all happened in seconds.
Sounds like a start capacitor problem to me. They are consumable, so 35 years is good going. Try to find what value in micro Farad it is and find something close with a 400 Volt rating to replace. It will only be a few pounds and is worth trying. It's a round cylinder wired to the motor..... but can only hear buzzing sound from the motor. Has anyone got any ideas my worse fears is the motor may have burnt out to say I am upset is an understatement.
