Chaps, I am in the process of making a desk using a solid oak worktop that is 2100 x 620 x 40mm with 40mm staves.
Ideally I just want legs at each end with no central support.
I am drawn to fitting either some Wickes finest 38 x 63 CLS on edge or some 50 x 30 steel box flat as a rib down the middle underneath using slotted holes to allow for the differential expansion. Is this likely to be overkill? I do like to over engineer.
