Deep(ish) Mortices For First Timer
Thanks all. I've discovered some unloved chisels in the darker recesses of my tool cupboard that I'm going to practice getting what will hopefully be a decent edge and then have a go at some scrap before I try the real thing.
So after a few hours sharpening (honing) and chopping with a 12mm bevel chisel I managed a reasonably decent mortice. So my next question is - given that the mortice should be 15mm or so, do I get a chisel that wide or chop from both sides. I used a version of the Paul Sellers mortice guide (made from some aluminium plate I had hanging around) so could just use that on either side of the mortice and just use the 12mm chisel I have, or I could just get a 14mm or 16mm chisel.
What would you suggest?
Should have been a little and often and taking up about a minute or two in total, several times during the chopping of a mortice.
It's when you are working hard with a chisel that modern sharpening fiddling about is just too time consuming. Back to basics - freehand, one medium oil stone.
Wrong chisel
Yes if it's a mortice chisel, 5/8" or 1/2", but otherwise you use whatever you have, as best you can, though a firmer would do better than a bevel edge.
A proper mortice chisel is a specialised tool designed for the job, with a technique all of its own. You could go there if you wanted to, otherwise just carry on as best you can with whatever is to hand.
Wrong chisel
Yes if it's a mortice chisel, but otherwise you use whatever you have, as best you can.
Thanks Jacob - the chisel was what I had to hand, and the sharpening was a learning curve for me, so I probably took longer than I needed to or should have done. I found 4 chisels and gave them all the treatment, and chopped the mortice - that was over the couple of hours I mentioned.
At the risk of asking a stupid question, what's the difference in technique between the two chisel types?
Not a stupid question at all! I had no idea myself until and old joiner patiently showed me how!
You cut out the whole mortice with a mortice chisel of same (chosen) width, a big mallet, no other tools.
Mark up the sides with mortice gauge, top and bottom if it's through, mark ends with a square
You hold it vertical at all times, no levering at all except a little pull back to loosen it from each cut, and also to clear the bottom of a blind mortice.
You bash it in anywhere but not at the ends, these you do last.
Loosen it out of first shallow cut and then repeat by paring off the vertical face of the cut and going deeper, repeat etc.
When close to the end turn around and work your way back, cutting through the chippings you've already made and going deeper with each cut, paring down the face of the previous one.
It's a fast and furious process and good for body building!
When halfway through turn it over and work from the other side, if it's a through mortice.
Otherwise work to a depth mark, felt tip mark or sticky tape.
Finish by cleaning the faces at the ends of the mortice with a last paring cut.
Clean out the bottom of a blind mortice by levering against the side with the curve of the bevel against it, and lever out any remaining chippings. Most of them will have just fallen out as you go.
Sharpen a little and often through the process.
Do it flat on a bench top un-clamped and not in a vice - there's a lot of heavy bashing and the clamps will mark the sides.
Better still do it between your legs sitting astride the workpiece over two saw stools, or even a purpose made morticing stool.
It's much the same process as you would apply with a hand powered morticing machine, just a series of powerful vertical paring cuts, close together, each one down the face of the previous one, not unlike digging a spade width trench with a spade.
Using the right size chisel means no cleaning up of the sides or fine adjustment, though it's helpful to have a hardwood (beech) drift same size as the tenon but longer, to bash though a through mortice to clear it out and check for straightness etc.
PS you can do it with a heavy firmer, but a trad pig sticker mortice chisel makes it much easier to control, and faster.
Having a chisel the same width as the slot will make the job a lot easier. One advantage in my experience is that you can align to just one side of the tenon. That's a lot simpler.
One thing that @Jacob alluded to but worth emphasising: stop a couple of millimetres short of the ends at each traverse. The final cuts are the ones that take the slot to full length. If you try to cut the slot to final length at the start of the process you'll find that the angle of the blade will push it into the final end wall and you'll either end up with an over long slot or irregular ends. With the slot short, you can take it to full length with thin shaving and creep up on final length. You'll get a much cleaner final result.
Size the mortice based on the chisel you have and once cut then make the tenon to match. Easy to fine tune the tenon, tougher to fiddle with the mortice.
Essential, if you want the full mortice chisel experience and to get the most out of it! Using a mortice chisel properly is a very particular process and they are (were) designed for the job.
Better with two lines done with a trad mortice gauge IMHO
None of the other respondents mentioned using a drill bit (ideally a Forstner bit which leaves a flat bottom) with a depth gauge - a bit of insulating tape wrapped around it does the job) to remove the bulk of the waste. I'd use a bit slightly narrower than the mortice and clean up with a chisel.
Agreed - but the original posting did state "I don't have a router or a drill press" which was why the conversation went the way of "what's the best way to cut mortises with just chisels".
Personally - if I'm going to involve a machine in mortise cutting I'll use a router.
For 6 mortises like this I'd drill using a brace and an auger bit. That'd make short work of the holes, and cleaning up with a chisel would be easy.
I've seen braces and auger bits at every car boot sale I've been to - budget for a tenner if you're happy to clean off a bit of rust.
