PhilipL
Small s. Does that make a difference to the rats?There are no states in Canada. Provinces and Territories only. America has the states.
Our biggest rats infest the government.
I don't think they give a S*** or even s***Small s. Does that make a difference to the rats?
Find holes then block with wire wool coarse best, broken glass(They can't chew that)and a mix of 3-1 sharp sand and cement.make sure damp round hole before filling that way cement mix bonds to hole.Thanks all for the helpful advice.
I would rather try and catch them dead, then alive, and have to deal with dispatching them myself (although I like the idea of buying an air rifle! ha)
I'm going to finely inspect my subfloor party walls and block anything that remotely looks like a hole (with steel wool and lime). And I'm going to push a mesh over my air bricks.
I still suspect they feed from the neighbours, and come into my subfloor to sleep and poop. But I will see what I can find.
In the meantime, I've ordered some heavy duty rat traps which should be here in the next few days.
BTW - great idea about the cat flap instead of the vent brick!! I would hate to be responsible for a neighbour's cat getting stuck under my house though...
I'm in ilford, redbridge. border of Essex and London.Find holes then block with wire wool coarse best, broken glass(They can't chew that)and a mix of 3-1 sharp sand and cement.make sure damp round hole before filling that way cement mix bonds to hole.
What part of London you in?
Check drain holes/covers as they push covers up/out!
Someone had them get up outside into roof then run through roof void into other places through gaps even though meant to be fireproofed!
I wish I had done that! I recently rebuilt the joists and floor in one room on the ground floor. I should have filled it all when I had the chanceI think the only answer is to rip the floor up and lay concrete.
Has it got anything to do with previous matter with stinky water/drainage issues with neighbourI wish I had done that! I recently rebuilt the joists and floor in one room on the ground floor. I should have filled it all when I had the chance
Both rats and mice can squeeze through surprisingly small gaps. Apparently they can compress their ribcages somehow, basically anywhere their head can get through - their bodies will follow.I completely agree with those who say block all entry points with wire mesh etc. Do not underestimate how small a hole they can get through.
I once heard "crackling" at a 13 Amp socket and thinking it was a loose wire, proceeded to remove the faceplate and found an electrocuted mouse. It was a metal backbox and with two cables and rubber grommet the gap was tiny (plastered block cavity wall). I know this was a mouse but I am still aware of how small a hole they will get through.I do agree that there does not need to be a food source, they will find that elsewhere.
At our previous house we had chickens which were a big draw for the rats. I made a bait box with an open front and placed it near the chicken house. It was about 25m from a caravan we had stored in the garden. I rigged up a camera with motion detect on the bait box which alerted me when we had visitors. I then took a comfortable seat in the caravan and enjoyed an eveningās entertainment popping the rats with my air rifle. All very civilised.Thanks all for the helpful advice.
