MikeG.
You're reaping the rewards now, DBT85, of having supported your formwork so well. The edge of the concrete is making a really neat junction with the brickwork, showing that it's straight (and in the right place).
I also used a lot of hex head timber screws for assembly of the panels and brackets, too expensive to use as a construction method for framing, but they would be no good for the OSB, nails are perfect, and gun driven ones at that. There will also be the cladding, I will use 500-600 51mm ones on that, paslode to the rescue again.AJB Temple":9hrdlrhl said:I 100% agree with Mike re using screws. I also use Reisser (bought in trade quantities) and pop them in with a driver. I also use Timberfix bolts a lot, again driven in with a driver and hex bolt thing which usually comes with a box of bolts. I will always do this in preference to nails in buildings as I think it a) does a better job and b) is reversible.
I bought a new Paslode 350i from eBay for £350. New they are usually£450+ so I think I can sell it for £300+ after I finish with it. I get the quickload nail packs from Supafixings, or same company on eBay if easier. All nails I use here are ring shank galvanised, and just about all the first fix guns use the same nails. I bought a 1100 pack of each to start with, but soon realised a 3300 pack is the way to go. Had I not got the bargain, I think I would have got the Dewalt battery one as all my cordless are Dewalt so would only need a bare unit.DBT85":1d29yjpn said:Oh chaps I'll definitely be using a gun and not a hammer (hammer) .
I'm all about taking on absurd projects that make me learn loads of new skills and cost me thousands of pounds, but I'm not crazy enough to frame it with a hammer!
I've told the hire place I want one for Thursday, but I could well buy one as sheptonphil did. It was something I thought about before though I'd have no idea which to get. The plan was to get the bulk of the 90mm nails in in a weeks hire (hire costs come out of someone elses pocket!), but there are a lot of battens and OSB to bang up too so buying one might be prudent for now. What one did you get Phil?
DBT85":1dzjhi5t said:Oh the third one is definitely coming out. The other two can stay.
Yhe idea for the block is to set the studs back a fraction meaning that the cladding comes down and sits nicely on the brickwork rather than sticking out over it by 50mm or so.
I did look at the dewalt this evening but I have none of their kit, not that that would be a major issue of course. I guess it might be sensible.
DBT85":31kikndc said:.......... I'm also not looking forward to trying to bed 2 7m long bits of 4x2 onto a DPC and some mortar........
DBT85":23xo6uag said:Oh the third one is definitely coming out. The other two can stay.
MikeG.":196lfgke said:DBT85":196lfgke said:.......... I'm also not looking forward to trying to bed 2 7m long bits of 4x2 onto a DPC and some mortar........
Why not? It's a doddle of a job. You staple the dpc to the underside of the 4x2, lay out your mortar bed, sit the wood on there, and start tapping until it's level. Your choice as to whether you house out for straps before or after, but if you do it before you can fasten the plates down immediately and leave it alone until you come to erect the frames. You can butt joint the the loins, or have a little play with scarf joints.
