Hi All,
I had been working flat out on the dining room the last couple of weeks (took time off work), so I thought I'd give an update since, well, this is the last thing I 'made', and it may help others stumbling on this thread in future.
As mentioned above, it's been flat out - I wish I had taken more pics but to be honest I just wanted to get on and squeeze every minute from every day. My teenage lads were a huge, huge help as well.
The aim was to remove the hearth, rotten wall (sole?) plates, and any rotten joists. Plus, I would also remove the internal plastering which was the wrong material.
Started off well enough, but I discovered that not only was there bad rot, but also woodworm. While I was here, i decided I would replace the lot - and have peace of mind. This is what it looked like once everything was ripped out:
There had been a catalogue of errors/bad building work throughout the years before:
Concrete render on walls;
Foil backed plasterboard on damp walls;
No DPM at all between wood and masonry;
The hearth, which was a cold bridge, was also bridging the DPC, causing the damp to spread up the walls;
This was all ripped out.
Here's a pic of a socket back-box, that was on a cement rendered damp wall - shows the extent and duration on the damp problem:
The hearth is now also gone - that was 1 cubic meter of cement and clay, all very damp:
Woodworm had spread to the passage as well, quite bad, but very luckily completely localised to one joist (above the un-lagged water mains pipe that attracted condensation, not a coincidence, I'm sure) and some local floorboards. All were also replaced:
With all the joists, wall plates replaced and installed properly this time, I also took the opportunity to install 3 under floor fans to keep the air moving:
This, together with three new telescopic vents, and a much clearer sub-floor, is helping with airflow. (The fans may not do much - some might say it does nothing, but it makes me feel I've done what I can...)
Slab (Rockwool RWA45 100mm) Insulation added, with netting - which is really a backup since the slabs fit quite tight.
So next on the list is re-plastering with lime, and then the cosmetic decorating/flooring etc.
