Hi All,
Help needed please. I have a room in my Victorian terraced house, where damp showed up in the last six months.
This room has an external wall facing the garden, and another wall which originally was external facing, but now joins the kitchen – an extension built 15 years or so ago, before I bought the house.
The other wall is internal facing, to the corridor, and the last wall is adjoining the neighbour’s property. See diagram below.
First thing I saw was damp rising on the neighbour’s wall. I monitored for 6 months, and the damp patch was getting bigger. So I took up the and took up the laminate flooring and removed the skirting board to see what was there.
The damp was rising from the hearth (the chimney breast had long been removed before I bought the house).
Strangely half the hearth was damp (actually, the part that would have been under the chimney breast), and the hearth itself was bone dry.
The wall is not damp, and the chimneys have been removed and capped, so it’s not coming from above.
I took a floor board up, next to the hearth, near the extension wall (C), to have a look.
There is a HUGE amount of mould, and it is very damp.
The room has laminate flooring and is used everyday, so I couldn’t take more flooring up, but took some pictures.
Looking across to the opposite wall, which is a garden facing wall (A), I see the mains water pipe and gas mains, which turn into the kitchen/extension (wall C).
I thought it was a leaky main pipe, but it could be condensation. I saw no leaks, but water droplets are definitely there. I’m not sure if it’s a slow leak, or condensation.
The other thought is, that the garden facing wall is causing this – the colour of the wall looks dark, which may be damp, and it could have traveling across the foundation walls across to the opposite wall where the hearth is.
Two years ago, I dug the garden down about a foot, because the previous home owners had concreted to over the slate DPC, causing damp on the garden facing wall. That is now gone, but could the damp be traveling across the room, from the garden foundation wall??
Looking at the foundation wall from the inside, it is definitely damp, but I think the slate DPC is preventing it traveling up.
There is one air brick on the garden facing wall, which was added when the garden was lowered, but I can’t see daylight coming through – it might be a wrong position, too high, or blocked. Maybe airflow is constricted.
It’s definitely open underneath through to wall D, but maybe I need to ventilate wall B (the garden wall)? But how can I do that effectively?
Advice needed please:
1) Does it look like a leaky mains pipe to you? Or just condensation?
2) Could it be that damp has travelled across the floor that way?
3) Should I remove the concrete hearth replace with wooden joists/flooring?
4) How can I stop this problem?
Many thanks – please let me know if you need more info or photos.
S.
S.
