Marineboy
Yes, thanks jackbequick for that detailed description of your experience and how to apply what you know to my situation. But i wouldn’t know a termite if I stepped on one
You're safe up there for now but they are moving north slowly!.... i wouldn’t know a termite if I stepped on one
If the tie bricks are flush each side then the cavity cant be more than 25mm i.e. a brick is nominal 225 x 100 x 75 and it's difficult for a brickie to keep that clear of mortar droppings unless it's filled with insulation though it can be done with care and would keep the inner leaf dry.
Sorry, thought you’d left the forum?It seems there is a cavity.....though not an interior stud wall wall. The way a brickie will clear the small cavity of mortar is to hang a rope horizontally below his work and pull it up to periodically clear the gap. Re-looking at the photo the slab looks 'rough as guts and has no membrane.The possibility is then that the garage was built as a different project . I don't know but there is obviously an issue irrespective of the photo when water can be trapped and sit between an impervious item and brickwork. Presumably there was some logic somewhere in building around the slab and not on top of it. "Why" doesn't help much at this stage. A six inch slab would suggest, if thought through at the time, maybe a truck or agricultural machinery or say a heavy lathe was intended to sit on it. I see no reo near the corner of the slab (presuming it is the slab in question) so whoever poured it may have thought 6 inch would be fine without reo. Four inch with mesh bonding it would typically be on in a garage
As the photos seemed ?? compared with the problem I worked on the text...One thing I seriously disagree with is advising an inexpert person to use a concrete cutter. They can be quite dangerous particularly with no experience in their behaviour. For the rest, yes and as I noted in my dissertation, we have to get down below the slab to get rid of the water.... The method I proposed presumed the slab at ground level and the technique I proposed with 12 x 18 inch trench, consolidated river sand and sloping for trench run-off , is sound. Voila
It's brass monkeys here Brian, they'd need woolly vests.You're safe up there for now but they are moving north slowly!
JackIt seems there is a cavity.....though not an interior stud wall wall. The way a brickie will clear the small cavity of mortar is to hang a rope horizontally below his work and pull it up to periodically clear the gap. Re-looking at the photo the slab looks 'rough as guts and has no membrane.The possibility is then that the garage was built as a different project . I don't know but there is obviously an issue irrespective of the photo when water can be trapped and sit between an impervious item and brickwork. Presumably there was some logic somewhere in building around the slab and not on top of it. "Why" doesn't help much at this stage. A six inch slab would suggest, if thought through at the time, maybe a truck or agricultural machinery or say a heavy lathe was intended to sit on it. I see no reo near the corner of the slab (presuming it is the slab in question) so whoever poured it may have thought 6 inch would be fine without reo. Four inch with mesh bonding it would typically be on in a garage
As the photos seemed ?? compared with the problem I worked on the text...One thing I seriously disagree with is advising an inexpert person to use a concrete cutter. They can be quite dangerous particularly with no experience in their behaviour. For the rest, yes and as I noted in my dissertation, we have to get down below the slab to get rid of the water.... The method I proposed presumed the slab at ground level and the technique I proposed with 12 x 18 inch (or 18 x18 is ok for a seepage trench, consolidated river sand and sloping for trench run-off , is sound. The concept is moving the water away trough natural drainage provided by us. In this case if there are a couple of brick courses below the slab (sitting on???) we have to get below that or else get the water away quickly so it doesn't much affect the brick...Of course ice /snow melting is another consideration . Voila
Oh..I dont know...there have been a few posting on here today in another thread..reminded me of Jacob!!
Sam
Ex-bloomin-actly!!The original question has certainly elicited vastly over complicated suggestions.
In essence, a vented gap needs to be created betwixt the wall and the slab.
Ideally extending below the internal floor level.
For belt and braces, a small landdrain should be installed (also vented), to carry
away any ground water flow.
The photo I put in a previous post shows a type of membrane ideal for this kind
of scenario. You can even concrete back up to it afterwards, leaving a neatly
finished job.
Hire a decent disc cutter and a medium sized breaker and crack on with it.
