SammyQ
Sam
Corrr!! That's heavy duty gear Daniel! Never used it, but I concur, that would stop damp for sure!
Sam
MikeG? Calling Mr. Garnham!! I know EXACTLY what his response to this would be!!Marineboy, I have not read all the posts but another avenue you can pursue is chemical injection damp proofing, this is very effective done properly and cost effective compared to other methods.
Have a look at Sovereign Chemicals https://www.sovchem.co.uk I know personally of several jobs where this was used all were successful. If you contact them they will have a local installer.
There is no point whatsoever in a chemical DPC as it won't work in this case where the external concrete slab is far too high and will definitely be higher than the internal floor and and dpc if there is one installed, the only effective solution is to cut back the external concrete and reduce ground level. I've encountered this many times and had to correct the issue or advise the removal of soil where that was the problem. Hard surface is often much worse as water pools and splashes resulting in inevitable water penetration through the brick and mortar.Marineboy, I have not read all the posts but another avenue you can pursue is chemical injection damp proofing, this is very effective done properly and cost effective compared to other methods.
Just seen MikeJhn post above --he's entitled to his opinion of course but mine differs 100% !
Thanks Jonm. My SDS breaker did the bit you can see in the photo but it took some time and effort. Just a question of patience unless I pay to get a pro in.Marineboy, I think you are on the correct track. Firstly I would check the gutters are all working or fit some if none are present, someone else has mentioned this.
The ground outside of your garage should be 150mm below the inside floor level. If you decide to lower the concrete then a disc cutter and breaker is a good idea as already mentioned by others. Remember that a large 300mm disc cutter (petrol or electric) is a bulky machine and will cut to a depth of say 120mm, ppossibly not enough to cut completely through the slab so you may need a second cut so the machine is inside the trench, so the wider the machine the wider the trench, you could be talking about a 450mm wide trench, it all depends on the depth and strength of the concrete. There will be a lot of debris to be removed and reinstatement.
You may be better employing a builder who already has the tools. Alternatively you could try a 230mm electric cutter which is smaller and an ordinary sds drill with hammer action, may work if the concrete is not too strong.
to effectively enclose the damp wall.
Why would he want to do that? He need's to tackle the problem at source which is what he's doing not hide it behind another wall. It's pretty clear what the problem is and the solution to sorting it the only question is how to cut the concrete and unless I misread the original post that concrete is 6"thick which will be slow painful work with DIY tools or relatively quick with hired industrial equipment.You have one heck of a problem. What I would do is build a single width block 4" thick about 2" minimum from the offending wall up to the ceiling. Make sure you use some DPC between the new wall and the damp wall at both ends, to effectively enclose the damp wall. Obviously this will effect your garage door, but it will stop the dampness which will not be doing your tools etc any good. I would also suggest you use Thermalite blocks not concrete as they are much lighter to handle. Ps I built my own bungalow 23 years ago.
