rob1713
I had a lucky find earlier this week when I was able to buy a wooden plough plane by D Kimberley with a full set of cutters for a very reasonable price.
The plane is in good condition and all of its 'bits' are with it and work properly.
After a very light wax and sharpen I gave it try out. It's an absolute delight to use, the 3 stem screw fence system makes setting up very easy and accurate. I like the fact that it is relatively big and heavy as this helps keep it on line when working with awkward grain.
The only issue i have found is that you cannot cut a shallow groove by working to the depth stop when the groove is less than 25mm from the fence as the cut out in the fence for the depth stop is not deep enough. It seems that this issue was well known as number of online pics of this plane that I found show the fence cut down.
It's covered with patent stamps so Mr Kimberley was obviously very happy with his work. All in all its a lovely tool which will get a lot of carefull use
