Oooo nice.
Being someone who has also spent a long time messing about making and tweaking cyclones (but not with any commercial interest), may I ask a few techy questions? What's the jointing strip adhesive and the glue you are using?
Is the plastic polycarb or something else??
The body material must be quite thin, to allow cold bending (particularly on the small versions which has a tighter radius at the bottom of the cone). To add to this the static pressure of shop vacs can be much greater than the higher airflow dust collectors, so... Is there any issue with the vacume deforming the walls of the cone when the vac's hose is restricted or blocked for example?
Anyway, good work, great to see this technology catching on over here and being used!
