AES
@Bm101:
There's nothing to disagree with in chaoticbob's post, on the contrary, BUT, a lot will depend on what "sort" (alloy) your ali is - some is pretty hard and will work-harden if it's bent regularly - that's just one example of "fings what can 'appen".
All the same, personally, if I had a suitable ali rod to hand, and didn't know it's spec (alloy type), I'd still give it a go, but your choice of course.
All that happens at the worst is that it will bend and then (probably) slowly break, meaning you start again using MS the 2nd time.
IF you do try ali, as well as my warning about "sticky" swarf above, DO use lubricant while threading. The books say paraffin, but if none available, I've found WD40 works as well.
Whatever you choose, good luck.
HTH
AES
HTH
AES
