Bumble
I'm on box making practice and using construction waste. It's some sort of decorative cladding and when I cut off the tongue, I'm cleaning it up to reuse on the box lids.
I was using a small block plane but struggled to get a uniform cut so am now using the router first to get a flat surface, fixing down the piece with tape and CA.
It was about minus seven degrees in the workshop this morning and CA was failing (not setting) and I was wondering if there was a better solution. How would you cut this?
I am also having difficulty with getting a good 45 degree cut leading to small gaps/bad fits. I'm taping the pieces down in a scrap wood cradle and after scoring first with a knife putting it under the mitre saw or using the hand saw but think this maybe should be a job for a plane. How do I get a clean and accurate 45 degree cut on 4mm trim?
Thank you for any help and Merry Christmas and a Happy New Year to all!
