Hi, thanks for accepting me. I've got a few woodworking projects coming up and figured that it might be a good idea to join up for some expert advice.
My first project is to fit a door drop seal onto an internal door. The groove needs to be 14mm wide and 35mm deep. I'm struggling to find a long 14mm router bit so I'm currently considering a 12.7mm and doing a pass off each side of the pencil line.
My other problem is that my router is my only power tool that's ancient, a hand me down of unknown brand. It doesn't have a fence, so I figure I'm resigned to either replacing it, buying a jig of some sort or shuttering it in with wood clamped either side of the door.. which is probably not going to be ideal.
The last option is using my rail saw, but given that the cut is on the end, I think I'm going to struggle placing the rail securely.
Any thoughts on the best way to do this please?
