I know that most folks with a small 'shop cut their sheet material outside. But i've figured a way of cutting sheet material on my 8 x 2 'bench.
Basically it is a sacrificial sheet of 18mm MDF ripped down to 900 mm clamped to the bench. The workpiece is then dropped onto the sacrificial sheet and both are secured together with clamps to the 'bench. The sheet is then ripped to length. It can also be used for crosscutting boards.
My 'shop is a single garage - 8' wide. But with this set-up it means I don't have to wait till the rain has stopped so I can get outside to cut up a board.
Karl
Karl
