Jeremy Nako
I've started to play with inlays using hardwoods such as Purple Heart, Padauk and mostly Walnut.
To-date I've been cutting down (thickish) off-cuts but I need to order some more stock, so I'm looking at 12mm thick stock, which suits me as my inlays are never deeper than 7mm.
On the suppliers website it warns of cupping when using such thin stock.
So.. two questions if I may..
Firstly.. is there an optimum -and practical - way to store the pieces to avoid as much as possible any cupping ?
Secondly.. should it occur, is there a sensible solution ?
This may sound daft, but would wetting the wood and then drying it under pressure (I have an old heat press that was used for T shirt printing) work ?
The inlays (very thin) would be glued in under pressure when used, so I'm not concerned with that (unless someone knows different !)
Any advice gratefully received.
