Crack filling
Superduner
22 Apr 2021
France
I'd like a bit of advice about filling cracks in the top of a gate which is open to the intense UV rays in southern France.
It's one of a pair and the other one is fine after 7 years but this one is severely cracked (cracked may not be exactly the right word here).
I've tried filling with all sorts of stuff. Hot glue, epoxy wood, water based wood filler but nothing stays around for more than a few months. It either squeezes out when the cracks close up a bit or falls out when the cracks open up in wetter weather.
It's there a product that will work in this situation?
The first thing that sprang to mind was whether polyethylene glycol or a wood hardener would stabilise this enough to let you refill the cracks with a conventional exterior filler. Other than that whether there is a pourable UV stable resin that would bond well enough.
Really just thoughts as a jumping off point than anything helpful I'm afraid
