DBT85
The ender 3 Pro is here. I already want an adapter to go from my mitre saw to my vac. Why do these bastards insist on making up random sizes!
It was 2 hours to print and yeah, you just leave it to it. If it had an issue you might come back to a spaghetti mess, but if you keep the occasional eye on it you can cancel it if its looking bad.marcros":135x2d8p said:Is that 2 hours to print or is there design time on top of that?
When it is printing, can you just leave it to it?
I'm sorely tempted by the banggood product. Have you hit any issues?DBT85":3bz8mrxy said:First print right off the bed. It was one of the models included in the printer so nothing fancy, no settings changed or anything. Not bad for a £196 printer.
20200514_190302
20200514_190258
This will easily do the bits I want it to do.
SkinnyB":1uz6qzto said:Here is my latest design 3D printed. 2 hours to print. I run a 1mm nozzle over the standard 0.4mm nozzle, so essentially I lay down plastic over twice as fast as a standard nozzle. This works great for the print I do as they tend to be big parts so really speeds up the time.
I wanted to put 150mm sanding discs (Mirka silver Ace only available in 150mm) on my Makita 125mm sander. So designed and 3d printed a larger plate for it. Added some foam and velcro and all under £5. The slotted design allows for suction holes outside of the 'body'
of the sander so it still pulls in dust from the very outer holes.
I also designed one to take 9 hole and 8 hole discs as I accidentally bought 9 hole instead of 8 hole once.
None at all, bu bear in mind its only been a couple of days. It has been printing things for about 24 hours so far in total, today just parts for itself like cable clips and stuff.Deadeye":1uz6qzto said:I'm sorely tempted by the banggood product. Have you hit any issues?
DBT85":14de55ix said:First print right off the bed. It was one of the models included in the printer so nothing fancy, no settings changed or anything. Not bad for a £196 printer.
20200514_190302
20200514_190258
I can make a steps per mm adjustment, but if a 20mm cube is nigh perfect I don't quite know what I'd need to adjust. I'll ask on reddit maybe.CHJ":3qbuin65 said:A calibration adjustment for the stepper motors in the firmware by any chance?
Yeah unless you have the desire to design your own stuff it is largely a bit of a toy.marcros":1d14bm41 said:This thread alone has been enough to confirm that I don't want a 3d printer. It is very interesting stuff, fascinating in fact, but I hadn't realised there was quite so much to it.
Can I ask why you changed it to 0.3 in the first place? I assume just for print speed. My nozzle is only 0.4 so I guess 0.2 is basically where I'll stay unless I get a larger tor smaller nozzle.SkinnyB":1x3gd04d said:And just by reducing the layer height back to 0.2mm we have a much better part.
IMG_8694 by jamie skinner, on Flickr
marcros":e980q06f said:This thread alone has been enough to confirm that I don't want a 3d printer. It is very interesting stuff, fascinating in fact, but I hadn't realised there was quite so much to it.
