YorkshireMartin
I've had this bandsaw for a while now, it's an old 351s. A lot of stuff is right with it and it seems to have plenty of power and resaw ability, thanks in no small part to the Tuffsaw blades.
The problem is the table, which is one of the cheaper pressed steel jobbies. It has depressions in it (from wear I assume) and I posted about this before. A variety of solutions was suggested, from overlaying plywood, to car body filler.
What I didnt know at the time though, was that it is also twisted. I've just found this out using a laser. It's quite a bit off. As you can imagine, depending on the width of the wood I'm cutting, I can get all sorts of results. Inaccuracies that you just can't really calibrate for. I've been scratching my head over it for weeks until the penny finally dropped and I managed to get hold of a laser to test it.
It's frustrating as the blade tracking and everything else is spot on.
I can't for the life of me think how to solve this. Obviously with a twisted table as a datum, any sort of overlay is going to useless and I can't grind it because it's so thin at 2.5mm or so and the twist is too significant.
I don't think steel like this can be reformed, so I'm not sure what options are left.
I'm considering a full table replacement using 38 or 50mm MDF, but I'm thinking that with the offset mounting point for the table on the saw, the MDF will distort, despite the thickness. I'm still going to try though because its the cheapest option.
Are there any other options out there? For example, what are the chances and likely costs of getting a table made out of cast iron or finding one used that i can regrind? I've never dealt with anything to do with metalwork so before I call a fabricator, it would be good to have an idea of what im looking at.
I only paid £400 for the machine, so if the costs climb too high, I might have to get rid. Would be a shame.
I hope someone can offer a ray of light.
Many thanks
Many thanks
