Hello,
I've tried searching but with no luck, so hopefully someone can answer these simple questions.
I'm now the owner of a Coronet Elf as my first lathe. Which I am using to attempt to make tool handles and the odd
Christmas tree decoration. The questions relate to some parts of the lathe and their use.
At the drive end of the lathe there is a large nurled disc about 30mm in diameter 20mm wide and with a hole in the centre. The drive spur sits in this, but often when putting a blank in the lathe the blank does not turn, if I slacken off the tailstock it turns the blank. What is the nurled disc called and what is the best way to set the correct tension?
Also I have what looks like a drill chuck, which instead of jaws it has 4 small pieces of metal which close in when tightened. What is this used for?
Sorry for the poor descriptions and thanks in advance.
