gregmcateer
Woody Alan,
I have used copper and plastic over the years, (JG Speedfit is my favourite plastic one).
If I understand you correctly, you are putting underfloor heating in solid downstairs - if so, I am not sure why you are using trays - that would be more likely if between joists. (Though I even used battens and screed between joists in one zone).
Regarding joints - I have just installed plastic pipe over 75mm of insulation board, then screeded with 75mm floor screed. It is over 50sqm, with 4-port manifold for the 4 zones. There are NO JOINTS under the floor - just four loops out and back to the manifold, as per the manufacturer's, (and all installers to whom I have spoken) advice.
I used kit from http://www.wundafloorheating.co.uk/ if that's any help.
Greg
Greg
