Benchwayze
Thanks Greg. Now I know where to start l'll follow my nose!
Enjoy a dram or two!
John
John
We have 2 electric ovens that are just the standard size but also have a huge brick oven in what we call the bakery. Even that is not big enough for a whole elk of course, even if we wished to cook one, so we'll just have a joint.just how big is your oven...............................................??
One doesn't buy elk. If you are not a member of a hunting club you have to know someone who is.Would one buy the whole elk when a chunk would do; and is elk as tasty as buffalo BTW?
That's how it used to be in UK with venison. My area manager at the time was a rifle fanatic and he got me a lovely joint of venison just before one Christmas. He wanted me to take over the branch as manager, but I had other plans. I cooked the venison before I told him.We have 2 electric ovens that are just the standard size but also have a huge brick oven in what we call the bakery. Even that is not big enough for a whole elk of course, even if we wished to cook one, so we'll just have a joint.
(Actually I have seen elk for sale in a supermarket: twice since I moved here in 1990.) It is easier to buy Kangaroo meat - which often appears in my local Lidl - than elk. Though to be honest I suspect the Kangaroo is not local produce.)
I have never tasted Buffalo so cannot compare it to elk.
Not at all - ham is bacon is cured pork. It's all the same stuff, but cooked slightly differently. It's exceptionally easy to make, and way, way nicer than the slimy, square stuff you get from the supermarket.How can you turn pork into ham? I have some leg of pork in the freezer and I like ham. Or have I missed something?
Anyway, to make a brine: for 1kg of meat, you need 421ml of water, 50 grams of salt, 25 grams of sugar and 5 grams of saltpetre. Disolve everything in the water, and then submerse the meat in the brine. NB that is not much water - I use a polythene bag which is sealed using a vacuum sealer to get all the air out. The meat should sit in the brine (never exposed to air) for one day for every half inch of meat to the centre of the joint, plus one day. For eg, if your joint is 4" thick, then the brine will penetrate from both sides, so only needs to travel 2" to get to the centre, which takes 4 days at half and inch per day. Then add your extra day for safety, and you get 5 days in the brine. Then, you need to take it out, rinse it off, and leave it uncovered in the fridge for a week so the salt concentration can even out. Otherwise it will be more salty at the edges than the centre.
Someone mentioned clotted cream. I could eat the cream, but the scones and the jam preclude a Cornish tea. Never mind eh?
Thanks Phil. Makes no difference to me of course. If there is starch in a 'split' then I can't indulge. However every cream tea I ever had in Kernow was served with what looked like scones. When the lock down is over I am coming down to Penzance. Maybe I shall order a tea with splits! Cheers and Merry Christmas.A Cornish cream tea should be with splits, not scones.
More salt. Possibly more saltpetre. You need to look into making specific types of hams and sausages, using the specific methods for aging the meat. It would help if you have access to a cave, or unheated basement. If you use facebook, this may be of help: https://m.facebook.com/groups/thesaltcuredpig/Technique aside, I thought 'a ham' was specifically pork leg, rather than any other cut?
Given that these are largely techniques for preserving meat in days before fridge/freezers, do you know how your instructions might need to be modified to cure without refrigeration? Fridge space is quite precious and I'd like to give it a go 'old school'.
Oh that's interesting. I make splits occasionally but I have always known them as "Devonshire splits", purely because that is how I have always heard them named. Is there any difference between a split from Devon & a split from Cornwall?A Cornish cream tea should be with splits, not scones.
My mother and grandmother were from StKeverne. The family left Cornwall in about 1925, but I'd never heard mother mention splits. I never knew my grandmother. Whether there were regional differences in Cornwall I wouldn't know.
Nigel.
Many regional differences, I expect. I've known people in my lifetime who hadn't been more that ten miles from where they lived. I've known people from twenty miles away whose accents and vernacular I couldn't understand, come to that.
