engineer one
steve,
like everybody i was trying to suggest a quick way to build
up strength, not unfortunately make the joinery easier.
i do however wonder whether there might be some logic in
moulding the cross piece that has been suggested onto the former
when you shape the back, i assume that you may well use some
kind of vacuum press to retain the shape. if you put retaining nuts into
the cross rail at the back before you glued it onto the back, maybe that would work. i.e. captive nuts hidden at the back of the cross piece.
it could be quite a thick section, and then the front legs could be studded into it.
another bit of stirring for the mix :evil: :evil: :evil:
good luck
paul :wink:
good luck
paul :wink:
