RobinBHM
I sometimes make boxes / drawers for a busy joinery shop. One on the simplest ways is to use 6mm ply for 2 sides and 12/15/18mm for the other 2. That way you still have a reasonably light construction but a thicker glueline and a thicker section to pin or screw into.
No rebating works fine but it is worth making a jig to clamp securely or you will struggle with getting good joints. Its best to make the ends a tad proud and sand flush, better than being underflush and then sanding through the veneer face.
If you decide to rebate, it is easiest to do the machining with larger panels of multiple drawer components then strip up to single parts.
The drawers arent very big, even 6mm ply will be very strong. Maybe glue in some little fillets to increase gluing area if you want to increase strength arounf the bottom.
Have you looked at layered foam inserts for the tools?
http://www.lifehacker.co.uk/2015/02/19/ ... tool-chest
